Hi all,
I was running ghost on a digital ocean droplet and updated from v3 to v4. As soon as the update was done I started getting 502 and 503 errors. ghost run worked but ghost start did not.
There are other threads mentioning such errors but none seem to stem from the issue I have:
Ghost seems to be looping indefinitely, looking at the logs it seems that there is an issue with port 2368 somehow being already used (I am not running multiple installs of Ghost as far as I know)
I have found mentions of such an error sporadically from 2017 to 2019 but cannot for the life of me find a working solution today. I have tried to force update ghost time and time again, as well as changing the port to 2369 in the config (which broke Ghost run). Nothing has worked until now.
The Droplet is running Ubuntu 18.04.6 LTS (GNU/Linux 4.15.0-158-generic x86_64)
node -v:
v14.17.6
Ghost version:
Ghost-CLI version: 1.17.3
Ghost version: 4.15.0 (at /var/www/ghost)
Ghost ls:
+ sudo systemctl is-active ghost_random-airship-io
│ Name │ Location │ Version │ Status │ URL │ Port │ Process Manager │
│ random-airship-io │ /var/www/ghost │ 4.15.0 │ running (production) │ https://random-airship.io │ 2368 │ systemd │
Ghost doctor:
✔ Checking system Node.js version - found v14.17.6
✔ Checking logged in user
Instance is currently running
ℹ Validating config [skipped]
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking free space
✔ Checking systemd unit file
✔ Checking systemd node version - found v14.17.6
Ghost log:
[2021-09-23 08:40:13] WARN Your site is now offline
[2021-09-23 08:40:13] WARN Ghost was running for a few seconds
[2021-09-23 08:40:15] INFO Ghost is running in production...
[2021-09-23 08:40:15] INFO Your site is now available on https://random-airship.io/
[2021-09-23 08:40:15] INFO Ctrl+C to shut down
[2021-09-23 08:40:15] INFO Ghost server started in 0.624s
[2021-09-23 08:40:15] INFO Database is in a ready state.
[2021-09-23 08:40:15] INFO Ghost database ready in 1.084s
[2021-09-23 08:40:19] INFO Ghost booted in 4.709s
[2021-09-23 08:40:19] INFO Adding offloaded job to the queue
[2021-09-23 08:40:19] INFO Scheduling job update-check at 9 21 7 * * *. Next run on: Fri Sep 24 2021 07:21:09 GMT+0000 (Coordinated Universal Time)
[2021-09-23 08:40:20] WARN Ghost is shutting down
[2021-09-23 08:40:20] WARN Ghost has shut down
[2021-09-23 08:40:20] WARN Your site is now offline
[2021-09-23 08:40:20] WARN Ghost was running for a few seconds
[2021-09-23 08:40:22] INFO Ghost is running in production...
[2021-09-23 08:40:22] INFO Your site is now available on https://random-airship.io/
[2021-09-23 08:40:22] INFO Ctrl+C to shut down
[2021-09-23 08:40:22] INFO Ghost server started in 0.637s
[2021-09-23 08:40:23] INFO Database is in a ready state.
Ghost log --error:
ERROR
MESSAGE: (EADDRINUSE) Cannot start Ghost.
level: normal
"Port 2368 is already in use by another program."
"Is another Ghost instance already running?"
InternalServerError: (EADDRINUSE) Cannot start Ghost.
at Server.<anonymous> (/var/www/ghost/versions/4.15.0/core/server/ghost-server.js:110:34)
at Server.emit (events.js:400:28)
at emitErrorNT (net.js:1347:8)
at processTicksAndRejections (internal/process/task_queues.js:82:21)
Has anyone had to deal with this issue recently? How have you been able to solve this?
Thank you!
