import axios from 'axios';
export default defineComponent({
async run({ steps, $ }) {
const GHOST_URL = 'VALID URL WAS PROVIDED HERE';
const GHOST_ADMIN_API_KEY = VALID KEY WAS PROVIDED HERE';
try {
// Fetch posts from the Admin API
const response = await axios.get(`${GHOST_URL}/ghost/api/admin/posts/`, {
headers: {
Authorization: `Ghost ${GHOST_ADMIN_API_KEY}`,
const posts = response.data.posts;
// Iterate through each post and check for 'automated-news' tag
for (const post of posts) {
if (post.tags.some(tag => tag.name === 'automated-news')) {
console.log(`Updating post ID: ${post.id}`);
// Hide the post by setting visibility to 'internal'
await axios.put(`${GHOST_URL}/ghost/api/admin/posts/${post.id}/`, {
posts: [{ visibility: 'internal' }]
headers: {
console.log(`Post "${post.title}" has been hidden from the homepage.`);
return { success: true, message: 'Posts tagged with "automated-news" are now hidden.' };
} catch (error) {
console.error('Error:', error.response ? JSON.stringify(error.response.data, null, 2) : error.message);
return { success: false, error: error.message, details: error.response ? error.response.data : null };
But the code run fails with this error message:
Error: {
“errors”: [
“message”: “Invalid token”,
“context”: null,
“type”: “BadRequestError”,
“details”: null,
“property”: null,
“help”: null,
“code”: “INVALID_JWT”,
“id”: “e3402e10-23f1-11f0-aee0-c5f3bd719293”,
“ghostErrorCode”: null
Hannah
2
Hi there,
I’m curious why you’re trying to build this yourself instead of using the client library?
There’s also a full example in the docs for how to use the key in JS
Use Javascript Client is great.
But keep an eye on this problem:
I would use fetch instead of axios.
Here is my VUE/NUXT code for ContentApi (not for AdminApi). But should be the same.
I have overwritten the method makeRequest.
import GhostContentAPI from "@tryghost/content-api";
// https://ghost.org/docs/content-api/javascript/
const API_URL = 'http://localhost:2369';
const API_KEY = 'xxx';
const API_VERSION = 'v5.115';
// Create API instance with site credentials
export const ghostApi = new GhostContentAPI({
url: API_URL,
key: API_KEY,
version: API_VERSION,
// see: https://forum.ghost.org/t/tryghost-content-api-nuxt-3/56495
// solution: https://forum.ghost.org/t/i-cant-use-local-ghost-content-ap/42502/12
makeRequest: fetchAPI
function fetchAPI({url = API_URL, method='get', params = {key: API_KEY}, headers = {"Accept-Version":API_VERSION}}) {
const apiUrl = new URL(url);
Object.keys(params).map((key) =>
// apiUrl.searchParams.set(key, encodeURIComponent(params[key]))
apiUrl.searchParams.set(key, params[key])
// console.log('makeRequest', apiUrl.toString(),method, headers);
return fetch(apiUrl.toString(), {method, headers})
.then(async (res) => {
// Check if the response was successful.
if (!res.ok) {
// You can handle HTTP errors here
throw new Error(`HTTP error! status: ${res.status}`);
// console.log('fetchAPI', res);
return {data: await res.json()};
.catch((error) => {
console.error("Fetch error:", error);
export async function getPosts(filter = '') {
return await ghostApi.posts
.browse({
limit: "all",
include: "tags",
// include: "tags,authors",
formats: "html,plaintext",
filter: filter,
.catch(err => {
console.error(err);
export async function getSinglePost(slug) {
.read(
{slug: slug, include: "tags", formats: "html,plaintext"},
.catch(err => {
console.error(err);
... and so on
