Ghost install - database and config problem
Hello,
2 years ago I installed ghost on a vps (debian6) :
  • node 4.5.0
  • ghost 0.9
Today I wanted to work on my website locally on windows 10 but I was not able to launch Ghost.
After some research I realized that it was very complicated to update ghost (0.9>1.25). And I realized that it was impossible to use my old database or config file…
So I just restarted :
1/ downloaded Ghost 1.25.3 with node 8.9,
2/ npm install
3/ i made a config.development.json in order to use mysql
“url”: “http://localhost:1337/”,
“server”: {
“port”: 1337,
“host”: “127.0.0.1”
“database”: {
“client”: “mysql”,
“connection”: {
“host” : “127.0.0.1”,
“user” : “root”,
“password” : “”,
“database” : “ghostbase”,
“charset” : “utf8”
4/ i launched mysql, and I used knex-migrator init in order to generate the fresh database
I just get an error…
I just want to install a new fresh Ghost with Mysql, but it seems really complicated…
Do you have an idea ?
another solution would be to keep my old configuration with node 4.5.0 but it seems risky?
Thanks
Hello!
U now try to integrate a updates from 0.9 up to 1.25. Its impossible.
  1. Save a backup your post.
  2. Reinstall your server from CentOS 6 into Ubuntu 16.04.
  3. Create your root MySQL user with u REAL root-password.
  4. Integrate backup with your new blog.
