I followed instructions in this blog. I provided the IP address of the instance to see if I am able to get the instance up and running first but I keep running into this error.
Has anyone else faced the same issue?
your MySQL is probably listening to the ipv6 version of localhost. Here’s discussion and a fix:
Hi, thank you. That removed the Connection refused error. But I am having a hard time figuring out how t restart Ghost.
I did the following.
ghost config url http://<MY_SERVER_IP>which throws this error
ghost restart
https://careers.ghost.org
Ghost instance is not running! Starting...
âś– Starting Ghost
A GhostError occurred.
Message: Ghost was able to start, but errored during boot with: Access denied for user 'root'@'localhost' (using password: NO)
Help: Unknown database error
OS: Ubuntu, v22.04.3 LTS
Node Version: v18.17.1
Ghost Version: 5.82.1
Ghost-CLI Version: 1.26.0
Environment: production
Command: 'ghost restart'
Additional log info available in: /home/ghost-mgr/.ghost/logs/ghost-cli-debug-2024-04-12T05_39_42_254Z.log
Ghost recommends I run the Ghost commands as ghost-mgr.
So I switched to that user.
Now it complains of an unknown database.
Should I reinstall Ghost again?
Ghost is installed as standard systemd service:
sudo systemctl restart 'ghost*'
It looks like you’re using root for the Ghost database use, which isn’t ideal. Typically, this MySQL account uses socket rather than password authentication. Therefore, run this code.
sudo mysql
ALTER USER 'root'@'localhost' IDENTIFIED WITH mysql_native_password BY '<YOUR-PASSWORD';
QUIT;
Running
root@<server>:~# sudo mysql
throws this error
sudo mysql
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
Try this.
sudo mysql -u root
Sorry that doesn’t work either
sudo mysql -u root
root@<server>:~# sudo mysql -u root -p
If you don’t know password for root, install mysql service one more time with full config.
If You don’t know how read my tutorial about using CloudPanel and docker.
In those steps You’ll have full working ghost instance.
Then use sudo mysql -u root -p.
