Hi all,
Been a while since I’ve used Ghost, giving it a try again on a VPS with 30G of disk space and 2GB of RAM, it seems to install correctly however when I have ghost install try to start it it replies with:
One or more errors occurred.
- GhostError
Message: Ghost was able to start, but errored during boot with: connect ECONNREFUSED ::1:3306
Help: Unknown database error
Suggestion: journalctl -u ghost_enigmatic-zone -n 50Debug Information:
OS: Ubuntu, v22.04.2 LTS
Node Version: v18.16.1
Ghost Version: 5.54.2
Ghost-CLI Version: 1.24.2
Environment: production
Command: ‘ghost install’Additional log info available in: /home/strange/.ghost/logs/ghost-cli-debug-2023-07-17T02_00_31_213Z.log
strange@blog:/var/www/enigmatic.zone$ cat /home/strange/.ghost/logs/ghost-cli-debug-2023-07-17T02_00_31_213Z.log
Stack: Error: Ghost was able to start, but errored during boot with: connect ECONNREFUSED ::1:3306
at Server. (/usr/lib/node_modules/ghost-cli/lib/utils/port-polling.js:73:28)
at Object.onceWrapper (node:events:627:28)
at Server.emit (node:events:513:28)
at emitCloseNT (node:net:2135:8)
at process.processTicksAndRejections (node:internal/process/task_queues:81:21)
When I try to run ghost doctor I get:
strange@blog:/var/www/enigmatic.zone$ ghost doctor
https://careers.ghost.org
Checking system Node.js version - found v18.16.1
Checking logged in user
Ensuring user is not logged in as ghost user
Checking if logged in user is directory owner
Checking system compatibility
Checking for a MySQL installation
- sudo systemctl is-active ghost_enigmatic-zone
- sudo systemctl reset-failed ghost_enigmatic-zone
Validating config
Checking folder permissions
Checking file permissions
Checking memory availability
Checking binary dependencies
Checking free space
Checking systemd unit file
Checking systemd node version - found v18.16.1
Other information that may be helpful:
strange@blog:/var/www/enigmatic.zone$ journalctl -u ghost_enigmatic-zone -n 50
Hint: You are currently not seeing messages from other users and the system.
Users in groups ‘adm’, ‘systemd-journal’ can see all messages.
Pass -q to turn off this notice.
– No entries –
Any suggestions on how to fix it? I’m using Ubuntu 22.04, with Nodejs 18.04.
