Ghost is not installing
I am trying to install ghost in my server but it showing this type of issues. How can I solve this?
eghost@ghost:/var/www/newsportal$ ghost install --db=sqlite3
✔ Checking logged in user
✖ Checking current folder permissions
✔ Checking operating system compatibility
One or more errors occurred.
1) Checking current folder permissions
Message: The directory /var/www/newsportal is not writable by your user. You must grant write access and try again.
Help: https://ghost.org/docs/install/ubuntu/#create-a-directory
    OS: Ubuntu, v16.04.6 LTS
    Node Version: v10.13.0
    Ghost-CLI Version: 1.14.0
    Environment: production
    Command: 'ghost install --db=sqlite3'
You can always refer to https://ghost.org/docs/api/ghost-cli/ for troubleshooting.
Did you read the linked articles, and try running ghost doctor as it says in the output?
Hey seems its permission issue…
Make sure the user(eghost) is in sudo group & the user have write permission on ghost folder(newsporta)
I tried. It is showing this issue
eghost@ghost:/var/www/newsportal$ ghost doctor
An error occurred.
Message: 'ENOENT: no such file or directory, lstat '/var/www/newsportal/content''
    Command: 'ghost doctor'
Additional log info available in: /home/eghost/.ghost/logs/ghost-cli-debug-2020-06-05T10_22_04_022Z.log
The user that is installing ghost needs permission to write to the folder
Can you confirm that you followed the steps outlined here?
I installed ghost but it is not starting. It is showing database error.
Can you check please?
eghost@ghost:/var/www/newsportal$ ghost start
+ sudo systemctl is-active ghost_newsportal-electronthemes-ghost-com
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
+ sudo systemctl start ghost_newsportal-electronthemes-ghost-com
+ sudo systemctl stop ghost_newsportal-electronthemes-ghost-com
✖ Starting Ghost: newsportal-electronthemes-ghost-com
A GhostError occurred.
Message: SQLITE_CANTOPEN: unable to open database file
Help: Unknown database error
Suggestion: journalctl -u ghost_newsportal-electronthemes-ghost-com -n 50
    Ghost Version: 3.18.1
    Command: 'ghost start'
Additional log info available in: /home/eghost/.ghost/logs/ghost-cli-debug-2020-06-06T04_13_22_669Z.log
Please take a look at this :smile:
