If anyone has a tried an tested method of getting a lightbox to work for post images then please respond, as its a little frustrating right now not knowing where I’m going wrong?
If you have a CDN for the link to the .js file it would also be great. My issue is that when i click an image it does zoom in, Im guessing this is standard behavior, but it only does one image at a time. I need to be able to right arrow, or swipe through images.
Have the same problem: tried all possible libraries in all possible ways, tried to follow all FAQs which I found – nothing helped, either for freshly uploaded images or for images, exported from Wordpress site.
Thank you, that helped me. I found where I made the mistake previously, maybe that will be useful. I tried to use fslightbox uploading the file to assets/js/lib folder, and even when I changed the path in config, it did not work. So I tried just to follow the manual and succeeded. Thank you once more!
