Hi there! The theme I’m using (Nurui by Fueko) uses a slightly different implementation of the Gallery card than the default Casper theme by Ghost does. You can see how it looks on their demo page, here.
I’d like to replace this with the default implementation, as shown in the official announcement blog post. I’d also be fine implementing Photoswipe or something similar. So far, I’ve tried the solutions listed in a few posts like this one and this one, but no dice yet. I also tried adding the Gallery CSS file to the assets/css folder and the Gallery JS to assets/js, but no luck.
Anyone have any advice for implementing an overwrite or new lightbox offering into a Ghost theme? Or anyone gotten Photoswipe to work (the docs were a bit daunting, to be honest!)?
Yeah sorry, might’ve used those a bit interchangeably. I just want readers to be able to swipe / arrow through photos, rather than the lightbox from the gallery only loading one file at a time (see how it works currently on my blog here.)
If I add that handlebar file from the Ease theme to my theme, is there a way to add that functionality?
Integrating Lightbox functionality will require some custom coding. The example from Ease is more of a guide of how it can be done—it’s not a drop-in solution.
Hey again! So I tried to get fslightbox installed, because the docs made it seems a bit more straightforward. I was also looking at this guide from Biron themes, though my theme is not from them.
I SSH’d into my hosting server, and installed fslightbox via npm. I also downloaded the JS file from their site, and put it in assets/js/fslightbox.js. Then, via code injection I added these lines:
The top is from the fslightbox docs, where I intended to call the application based on where I put it in my theme. The bottom code is from the Biron themes guide, targeting the gallery cards. Unfortunately, did not get it to work so far. I looked through the theme I’m using for how the gallery is built and called, but didn’t find anything that seemed relevant in default.hbs, posts.hbs, etc. There are a few styling options in the CSS file, but I figured that was not it.
Just want to make it so people can swipe or arrow through images in a gallery when in lightbox view. Would appreciate any help getting that set up. Thanks!
