‘ghost start’ just wont work and hangs forever.
Followed all instructions here - How to resolve errors when running ghost start - Ghost Developers
Read up on all similar blog posts and taken recommended action - but not seen my error before.
- What’s your URL? This is the easiest way for others to debug your issue
https:blog.richardcrosby.co.uk
- What version of Ghost are you using?
Latest
- What configuration?
Typical and validated. Tried the ‘remove bootstrap port’ trick but no luck.
- What browser?
Chrome
‘ghost run’ stalls forever. If I run ‘sudo systemctl start ghost_blog-richardcrosby-co-uk’
● ghost_blog-richardcrosby-co-uk.service - Ghost systemd service for blog: blog-richardcrosby-co-uk
Loaded: loaded (/var/www/ghost/system/files/ghost_blog-richardcrosby-co-uk.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2019-12-31 02:39:32 UTC; 17s ago
Docs: https://docs.ghost.org
Process: 31557 ExecStart=/usr/bin/node /usr/local/bin/ghost run (code=exited, status=1/FAILURE)
Main PID: 31557 (code=exited, status=1/FAILURE)
Dec 31 02:39:32 itsaunixsystem systemd[1]: ghost_blog-richardcrosby-co-uk.service: Service hold-off time over, scheduling restart.
Dec 31 02:39:32 itsaunixsystem systemd[1]: ghost_blog-richardcrosby-co-uk.service: Scheduled restart job, restart counter is at 5.
Dec 31 02:39:32 itsaunixsystem systemd[1]: Stopped Ghost systemd service for blog: blog-richardcrosby-co-uk.
Dec 31 02:39:32 itsaunixsystem systemd[1]: ghost_blog-richardcrosby-co-uk.service: Start request repeated too quickly.
Dec 31 02:39:32 itsaunixsystem systemd[1]: ghost_blog-richardcrosby-co-uk.service: Failed with result 'exit-code'.
Dec 31 02:39:32 itsaunixsystem systemd[1]: Failed to start Ghost systemd service for blog: blog-richardcrosby-co-uk.
Any help much appreciated.
