Hi, I am installing Ghost on Ubuntu v22.04.1 LTS but Ghost can not start.
Here is the output of ghost install:
✔ Configuring Ghost
✔ Setting up instance
+ sudo chown -R ghost:ghost /usr/share/nginx/html/blog/content
✔ Setting up "ghost" system user
ℹ Setting up "ghost" mysql user [skipped]
? Do you wish to set up Nginx? Yes
+ sudo mv /tmp/blog/blog.conf /etc/nginx/sites-available/blog..conf
+ sudo ln -sf /etc/nginx/sites-available/blog.conf /etc/nginx/sites-enabled/blog.conf
+ sudo nginx -s reload
✔ Setting up Nginx
? Do you wish to set up SSL? No
ℹ Setting up SSL [skipped]
? Do you wish to set up Systemd? Yes
+ sudo mv /tmp/blog/ghost_blog.service /lib/systemd/system/ghost_blog.service
+ sudo systemctl daemon-reload
✔ Setting up Systemd
+ sudo systemctl is-active ghost_blog
? Do you want to start Ghost? Yes
+ sudo systemctl start ghost_blog
✖ Starting Ghost
One or more errors occurred.
1) ProcessError
Message: Command failed: /bin/sh -c sudo -S -p '#node-sudo-passwd#' systemctl start ghost_blog
Failed to start ghost_blog.service: Unit ghost_blog.service not found.
Exit code: 5
OS: Ubuntu, v22.04.1 LTS
Node Version: v14.20.0
Ghost Version: 5.13.0
Ghost-CLI Version: 1.23.0
Environment: production
Command: 'ghost install'
Here is the output of ghost doctor:
✔ Checking system Node.js version - found v14.20.0
✔ Checking logged in user
+ sudo systemctl is-active ghost_blog-quangnv-com
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking free space
✔ Checking systemd unit file
✔ Checking systemd node version - found v14.20.0
Please help, thanks in advanced.
