I updated my Ghost installation but it is not working.
eghost@ghost:/var/www/menia$ ghost install v4 --db=sqlite3
Love open source? We’re hiring Node.js Engineers to work on Ghost full-time.
https://careers.ghost.org/product-engineer-node-js
│ Ghost 3.x and below have reached end-of-life status. │
│End-of-life software does not receive bug or security fixes, please update your Ghost version.│
│ See https://ghost.org/docs/faq/major-versions-lts/. │
│Warning: MySQL 8 will be the required database in the next major release of Ghost.│
│ Make sure your database is up to date to ensure forwards compatibility. │
✔ Checking system Node.js version - found v14.17.0
✔ Checking logged in user
✔ Checking free space
✔ Setting up install directory
✔ Downloading and installing Ghost v4.48.0
✔ Finishing install process
? Enter your blog URL: https://menia.electronthemes-ghost.com/
✔ Configuring Ghost
✔ Setting up instance
+ sudo chown -R ghost:ghost /var/www/menia/content
✔ Setting up "ghost" system user
? Do you wish to set up Nginx? Yes
+ sudo mv /tmp/menia-electronthemes-ghost-com/menia.electronthemes-ghost.com.conf /etc/nginx/sites-available/menia.electronthemes-ghost.com.conf
+ sudo ln -sf /etc/nginx/sites-available/menia.electronthemes-ghost.com.conf /etc/nginx/sites-enabled/menia.electronthemes-ghost.com.conf
+ sudo nginx -s reload
✔ Setting up Nginx
? Do you wish to set up SSL? Yes
? Enter your email (For SSL Certificate) electronthemes@gmail.com
+ sudo /etc/letsencrypt/acme.sh --upgrade --home /etc/letsencrypt
+ sudo /etc/letsencrypt/acme.sh --issue --home /etc/letsencrypt --server letsencrypt --domain menia.electronthemes-ghost.com --webroot /var/www/menia/system/nginx-root --reloadcmd "nginx -s reload" --accountemail electronthemes@gmail.com+ sudo mv /tmp/menia-electronthemes-ghost-com/menia.electronthemes-ghost.com-ssl.conf /etc/nginx/sites-available/menia.electronthemes-ghost.com-ssl.conf
+ sudo ln -sf /etc/nginx/sites-available/menia.electronthemes-ghost.com-ssl.conf /etc/nginx/sites-enabled/menia.electronthemes-ghost.com-ssl.conf
✔ Setting up SSL
? Do you wish to set up Systemd? Yes
+ sudo mv /tmp/menia-electronthemes-ghost-com/ghost_menia-electronthemes-ghost-com.service /lib/systemd/system/ghost_menia-electronthemes-ghost-com.service
+ sudo systemctl daemon-reload
✔ Setting up Systemd
+ sudo systemctl is-active ghost_menia-electronthemes-ghost-com
? Do you want to start Ghost? Yes
+ sudo systemctl start ghost_menia-electronthemes-ghost-com
+ sudo systemctl stop ghost_menia-electronthemes-ghost-com
✖ Starting Ghost
One or more errors occurred.
1) GhostError
Message: Ghost was able to start, but errored during boot with: (EADDRINUSE) Cannot start Ghost.
Help: Is another Ghost instance already running?
Suggestion: journalctl -u ghost_menia-electronthemes-ghost-com -n 50
OS: Ubuntu, v16.04.7 LTS
Node Version: v14.17.0
Ghost Version: 4.48.0
Ghost-CLI Version: 1.21.0
Environment: production
Command: 'ghost install v4 --db=sqlite3'
Additional log info available in: /home/eghost/.ghost/logs/ghost-cli-debug-2022-05-24T09_10_48_920Z.log
Do you have any other Ghost instances installed or running? Try changing the port (ghost config set server.port 2400) and restarting to see if it will fix the issue
Of course, then your admin panel will move to http://localhost:2400/ghost
Looked like a local install…
Hi Vikas,
Thank you for your reply.
I tried after changing the server port but it is showing the same issues.
"url": "https://menia.electronthemes-ghost.com/",
"server": {
"port": 2400,
"host": "127.0.0.1"
The issues
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking systemd unit file
✔ Checking systemd node version - found v14.17.0
✖ Starting Ghost: menia-electronthemes-ghost-com
A GhostError occurred.
Command: 'ghost start'
Additional log info available in: /home/eghost/.ghost/logs/ghost-cli-debug-2022-05-24T16_57_42_235Z.log
Could you please check again?
Can you share the log in: /home/eghost/.ghost/logs/ghost-cli-debug-2022-05-24T16_57_42_235Z.log?
There is no log file stored in the location
I got logs file in the ghost installation location /var/www/menia/content/logs/ but those are also empty
Those are the Ghost logs, we need to check the CLI logs.
What happens when you run journalctl -u ghost_menia-electronthemes-ghost-com -n 50?
This is showing when I run journalctl -u ghost_menia-electronthemes-ghost-com -n 50
eghost@ghost:/var/www/menia$ journalctl -u ghost_menia-electronthemes-ghost-com -n 50
Hint: You are currently not seeing messages from other users and the system.
Users in the 'systemd-journal' group can see all messages. Pass -q to
turn off this notice.
No journal files were opened due to insufficient permissions.
Try running the same command with sudo
I got this message
eghost@ghost:/var/www/menia$ sudo journalctl -u ghost_menia-electronthemes-ghost-com -n 50
-- Logs begin at Wed 2022-05-25 01:17:50 UTC, end at Wed 2022-05-25 04:10:40 UTC. --
May 25 04:10:14 ghost.electronthemes-ghost.com node[21433]: Love open source? We’re hiring Node.js Engineers to work on Ghost full-time.
May 25 04:10:14 ghost.electronthemes-ghost.com node[21433]: https://careers.ghost.org/product-engineer-node-js
May 25 04:10:14 ghost.electronthemes-ghost.com node[21433]: - Inspecting operating system
May 25 04:10:15 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:15] INFO Ghost is running in production...
May 25 04:10:15 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:15] INFO Your site is now available on https://menia.electronthemes-ghost.com/
May 25 04:10:15 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:15] INFO Ctrl+C to shut down
May 25 04:10:15 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:15] INFO Ghost server started in 1.207s
May 25 04:10:15 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:15] INFO Bootstrap client was closed.
May 25 04:10:15 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:15] WARN Database state requires initialisation.
May 25 04:10:16 ghost.electronthemes-ghost.com systemd[1]: Stopping Ghost systemd service for blog: menia-electronthemes-ghost-com...
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] WARN Ghost is shutting down
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] WARN Ghost has shut down
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] WARN Your site is now offline
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] WARN Ghost was running for a few seconds
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] ERROR Server is not running.
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: Server is not running.
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: Error Code:
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: ERR_SERVER_NOT_RUNNING
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: ----------------------------------------
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: Error [ERR_SERVER_NOT_RUNNING]: Server is not running.
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: at Server.close (net.js:1606:12)
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: at Object.onceWrapper (events.js:482:28)
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: at Server.emit (events.js:376:20)
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: at emitCloseNT (net.js:1659:8)
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: at processTicksAndRejections (internal/process/task_queues.js:81:21)
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: newsletters
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: posts
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: posts_meta
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: users
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: oauth
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: posts_authors
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: roles
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: roles_users
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: permissions
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: permissions_users
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: permissions_roles
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: settings
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: tags
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: posts_tags
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: invites
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: brute
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: sessions
May 25 04:10:16 ghost.electronthemes-ghost.com node[21433]: [2022-05-25 04:10:16] INFO Creating table: integrations
May 25 04:10:16 ghost.electronthemes-ghost.com systemd[1]: Stopped Ghost systemd service for blog: menia-electronthemes-ghost-com.
