Hi there!
I am new to ghost so excuse me in advance for the newbie question
I am trying, following the official documentation, to run the deploy ghost theme GH action using a self hosted runner on my webserver. Below the action in my workflow file:
on:
push:
branches:
- master
- main
jobs:
deploy:
runs-on: self-hosted
steps:
- uses: actions/checkout@v4
- name: Deploy Ghost Theme
uses: TryGhost/action-deploy-theme@v1.6.6
with:
api-url: ${{ secrets.GHOST_ADMIN_API_URL }}
api-key: ${{ secrets.GHOST_ADMIN_API_KEY }}
Unfortunatey, the deploy action fails with this error:
AxiosError: self-signed certificate
at AxiosError.from (/home/***/ghost-blog/actions-runner/_work/_actions/TryGhost/action-deploy-theme/v1.6.6/dist/index.js:39527:14)
at RedirectableRequest.handleRequestError (/home/***/ghost-blog/actions-runner/_work/_actions/TryGhost/action-deploy-theme/v1.6.6/dist/index.js:41777:25)
at RedirectableRequest.emit (node:events:514:28)
at eventHandlers.<computed> (/home/***/ghost-blog/actions-runner/_work/_actions/TryGhost/action-deploy-theme/v1.6.6/dist/index.js:5543:24)
at ClientRequest.emit (node:events:514:28)
at TLSSocket.socketErrorListener (node:_http_client:495:9)
at TLSSocket.emit (node:events:514:28)
at emitErrorNT (node:internal/streams/destroy:151:8)
at emitErrorCloseNT (node:internal/streams/destroy:116:3)
at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
at Axios.request (/home/***/ghost-blog/actions-runner/_work/_actions/TryGhost/action-deploy-theme/v1.6.6/dist/index.js:42567:41)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async main (/home/***/ghost-blog/actions-runner/_work/_actions/TryGhost/action-deploy-theme/v1.6.6/dist/index.js:43140:9) {
code: 'DEPTH_ZERO_SELF_SIGNED_CERT',
cause: Error: self-signed certificate
at TLSSocket.onConnectSecure (node:_tls_wrap:1659:34)
at TLSSocket._finishInit (node:_tls_wrap:1070:8)
at ssl.onhandshakedone (node:_tls_wrap:856:12) {
I have already installed the GitHub certificate in the ubuntu certificate store for my self-hosted runner. Also a copy of my letsenctypt certs for my domain are stored under /etc/ssl/certs.
Can someone kindly provide some suggestions?
Thanks in advance!
