Handlebars restriction in later versions?
I’m updating some of my early 3.x themes, and i suddenly get error on invalid hbs;
“Oops! You seemed to have used invalid Handlebars syntax. This mostly happens, when you use a helper that is not supported.”
The culprit is populating slots in a partial (Partials | Handlebars)
The partial card.hbs:
<div>
  {{#> slot-1}}Header-slot{{/ slot-1}}
  <hr />
  {{#> slot-2}}Header-slot{{/ slot-2}}
</div>
The template using card.hbs:
{{#> card}}
        {{#* inline "slot-1"}}
               <CONTENT>
        {{/ inline}}
        {{#* inline "slot-2"}}
               <CONTENT>
        {{/ inline}}
{{/ card}}
Is there now a more idiomatic way of doing this?
EDIT: Fails in latest, works fine in 3.42.5 at least…
Cheers,
Flemming
