Hiding some stuff from URL card
Is there a way to hide the site name and author name from the URL card that shows up when you paste a URL in an article?
If you’re talking about the website, yes. Use code injection. For email, no, or use some custom html.
Thanks Cathy
ideally for both web and newsletter but I guess I could start with the web. Would be awesome if anyone could share the code injection for that.
I think a general “how to hide X” answer is needed here :blush:
Basically, you need to inspect that element in browser (right click the element you want to hide, select Inspect Element). Check if that element has a specific class attribute, or an id attribute. Then write a simple CSS code in code injection like:
<style>
.class-name-of-the-element {
   display: none;
</style>
or
<style>
#id-name-of-the-element {
   display: none;
</style>
For bookmark card site and author name is inside an element with a class name kg-bookmark-metadata. So a like below will hide the author data from all of the bookmarks.
<style>
.kg-bookmark-metadata {
  display: none;
</style>
This removes that element from layout, which reduces the height of Bookmark card. Alternatively, you can use opacity: 0; instead of display: none; if you want to keep the size of bookmark card as is.
CSS is awesome, and I suggest everyone to check basic CSS writing knowledge for a better internet experience. You can customize all of the websites you visit with simple CSS codes with some browser extensions [1] [2]. :blush:
  1. ↩︎
  2. ↩︎
Thank you- this is very helpful!
