Hello, I’m working with Casper Theme and I want to disable the post cover option in the ghost admin panel but I can’t find where to disable it.
ghost > settings > design & branding > customize > post > post image style > hidden.
Thank you for your reply but that did not work. I am trying to disable publication cover option in brand section.
I’m afraid you cannot, that’s for the background under the logo in the home page. If you don’t select any it should show a black color or the accent color.
Thank you for your time
