i am a new user of Ghost. I use the Arate template.
I have an issue with the " Publication cover (An optional large background image for your site)". Indeed i wanna use a a very shinny picture but when i use it, Ghost display a pretty dark one.
I dont understand why
On the right is the color i used, and on the left the displayed one
Dark overlay is added to the ‘publication cover’ - to make the text visible on image.
If you only want the default orange color, delete the publication cover.
If you want to remove the dark overlay, go to the Code injection settings in the Ghost admin and paste this code into the Site header section:
Themeforest uses <iframe> element. The way iframes basically work is that they let you display a different webpage on some portion of your own webpage by embedding it.
In your case, it’s better to add additional graphic elements to your theme files to get a similar result.
This would set add an additional /featured/ URL address for all posts has been marked as featured. The main collection excludes these same posts to avoid any overlap.
