How can I hide few tagged posts from not showing in the homepage - Headline Theme
Hi, I write at melvinraj.com. I however don’t want my newsletter posts to be shown in the recent and as a post. How can I make it happen?
Any feedback is appreciated.
There are essentially two methods: you can modify the Routes.yaml file, or you can hand-code the filter into your home page. I have some of both on my site, and it took a good bit of digging around to finally get it to work the way I want.
Do you have a local install to experiment on? That would be a first step.
I can share my code at some point, but first you might spend some time looking at the documentation for getting posts and for filtering those posts.
Thanks, Bruce.
I am currently in the starter plan so, I don’t think I can experiment with code. Maybe when I have the right amount of sub-count.
Unfortunately editing Routes.yaml doesn’t work for Headline the way it does with other themes. Not sure why.
