More often than not, purpose is something forged, not found.
You donโt stumble upon your thing by thinking through every possibility. Instead, you try, fail, experiment, and pull yourself into the lightbulb moments origin stories are made of.
Your thing is out there. It just needs you to take the first few steps.
In this weekโs issue:
- Prolific. What separates you from mega-successful creators is less than you think.
- Momentum. How to say yes to the right opportunities.
- Results. Wh
The Ghost Newsletter
