Hi, i want to ask.
I have ghost installed on digitalocean droplet .
I know how to connect domain.
But i am confused when it comes to use it with subdomain.
where do i need to add the DNS record for subdomain? is it on digitalocean’s DNS manager or namecheap’s DNS manager or both?
just some note :
my domain is bantudesign.website which already connect to firebase hosting.
now i want to add blog.bantudesign.website for my blog.
my domain name registrar is namecheap .
Well I suppose lets start with something a bit basic and build up from that.
I’m going to assume you are using namecheap for DNS management. They are the authority of where one looks for your domains/subdomains.
You probably have an A card entry that tells everyone if want bantudesign.website then go to the following address 151.101.1.195. So on namecheap side you will need to create a new entry letting the world know what the address is to blog.bantudesign.website.
So I suppose the first question should be are you hosting both bantudesign.website and blog.bantudesign.website on the same droplet? If the answer is no, then you should be fine just adding another A card entry with the new IP address. If the answer is yes then you probably want to look into setting up a revers proxy.
so basically i just need to add DNS record to namecheap DNS manager?
no need to add into digitalocean’s DNS manager?
Correct.
I don’t use Digital Ocean (DO), but I can’t think of a reason why you would/could touch the DNS info on DO… as namecheap is your DNS hosting provider. You will need to tell the software on your droplet what to do when it gets a request for blog.bantudesign.website.
For instance I personally use Hover (for now) and my domain name registrar; I then use CloudFlare as my DNS hosting provider. I then host content from multiple providers… one of those instances is vultr, which is similar to DO. Let say my domain is ya-dweeb.com which is a basic splash/info page. I then have two subdomain one blog.ya-dweeb.com and gallery.ya-dweeb.com
On my machine instance I have a reverse proxy listing on port 80 and 443 when I get a request to gallery.ya-dweeb.com or ya-dweeb.com the proxy hands off the request to my nginx server. However, if gets a request for blog.ya-dweeb.com it hands the request off to the ghost (node) server.
