How to determine a posts visibility
I’m creating a custom theme at the moment.
I need to determine a post’s visibility (public, members, paid) but am struggling. Currently I have this conditional to test if a post is currently not visible to the viewer:
{{#unless access}}
    {{#has visibility="paid"}}
        <p>This is a paid article</p>
    {{/has}}
        {{#has visibility="member"}}
    <p>This is a member's article</p>
    {{/has}}
    <p>This will show if the viewer can't see the contents</p>
{{/unless}}
The theme is correctly showing the <p>This will show if the viewer can't see the contents</p> line but the {{#has visibility="paid"}} bit isn’t working.
Am I misunderstanding the use case here?
Hi @garrypettet,
There is one mistake in the code, the visibility is members not member.
{{#has visibility="members"}}
{{/has}}
I did a quick check in my local Ghost instance and this works for paid and members posts (texts show up as expected).
Great spot. Thanks!
