How to do Post Series?
This is not an original idea, but I’d like to bring this to the table so that we can discuss.
It was asked before about a month ago here but what I want is to have this as a functionality rather than a theme-level hack.
You can check this website to understand what “series” means in this context: www.cachestocaches.com. I’m giving this example, because in the past Medium also announced something called “series” but it is not what I’m asking.
If you open the webpage above, you’ll see a section that shows the details of blog posts on the right. It shows their categories, tags, publish dates, authors and most importantly, series.
Imagine a situation that you’re writing 5 posts that are explaining different parts of the same topic. They might have different tags, that’s totally fine. They might even belong to different categories. But without using a common tag, it’s impossible to gather these posts under the same page. This is where “series” comes in.
I hope this makes sense and I hope you consider building the feature.
Any feedback is more than welcome.
Cheers,
G.
I think this can be implemented via:
https://docs.ghost.org/docs/dynamic-routing
Hi @dsecareanu,
Thank you for your reply. But it’s again another hack.
So, for every series, I need to create a route entry.
routes:
  /series/from-zero-to-hero-something/: series-from-zero-to-hero-something
  /series/how-to-build-a-successful-company/: series-how-to-build-a-successful-company
Then, I need to create these hbs files, so that I can do this:
https://example.com/series/from-zero-to-hero-something/       -> series-from-zero-to-hero-something.hbs
https://example.com/series/how-to-build-a-successful-company/ -> series-how-to-build-a-successful-company.hbs
As I said above, I’m not looking for a hack to implement this, what I want from development team is that to implement this as a core functionality. So that we won’t have to use unnecessary hacks.
I hope it’s more clear now what I’m asking and why.
Cheers,
G.
Dynamic routing is not a hack. It’s a feature. And your use-case is made possible with that feature.
There are lots of ways to build different post series, and you certainly do not need to create a manual route for every entry - so it sounds like you haven’t read the docs which you’ve been linked to yet :slight_smile:
Moved topic to Themes category because this is not a new feature
