How To Exclude Specific Posts from the Home Page
Step 1: In the ghost admin, Tags, add a new Internal Tag #noindex. You will add this tag to any post or page that you want to exclude from appearing on the home page.
Step 2: In the Casper theme, in the index.hbs, edit the following code in between {{#foreach posts}} and {{/foreach}} like this…
        {{#foreach posts}}
            {{!-- exclude #noindex --}}
            {{#has tag="#noindex"}}
                {{!-- nothing --}}
            {{else}}
            {{> "post-card"}}
            {{/has}}
        {{/foreach}}
So the Main Content Area section should now look like this:
{{!-- The main content area --}}
<main id="site-main" class="site-main outer">
<div class="inner posts">
    <div class="post-feed">
        {{#foreach posts}}
                {{!-- nothing --}}
            {{else}}
            {{> "post-card"}}
            {{/has}}
        {{/foreach}}
    </div>
</div>
</main>
I lifted this code from…
For your specific use case, you should be able to simply use {{^has tag="#noindex"}} to select posts without the internal tag =)
Hey @itsmingjie thank you for that!
I’ve been posting more on this forum over the holidays, and it’s been pretty quiet.
I was beginning to wonder if this REALLY WAS a “ghost” forum (like an abandoned “ghost ship” spookily adrift on the sea.)
So here’s how I applied that in my index.hbs…
{{#foreach posts}}
    {{!-- Exclude posts tagged #noindex --}}
            {{> "post-card"}}
    {{/has}}
{{/foreach}}
I tried to get this working by ignoring multiple tags and without affecting the display styles of the styles in Casper (so at the foreach level). The best way I found it was to adding the filtering in the routes.yml:
In this way pagination will count all the excluded item as this logic is inside the foreach and if you have added 9 posts limit and your latest 9 items or 5 items comes with the excluded tag then only blank or 4 item will be display.
Hi Friends. Looking at the examples here I couldn’t get it to work because my homepage only should have 1 post on it. When excluding based on the tag the results were empty! Not exactly what you’d want.
Here is solution for getting all posts excluded by tag
    {{#get "posts" filter="tags:-hash-noindex" limit="1"}}
        {{#foreach posts}}
            <article class="gh-article {{post_class}}">
                {{> content}}
            </article>
        {{/foreach}}
    {{/get}}
Here is solution for getting only one result from a specific tag “changeme”
    {{#get "posts" filter="tags:[changeme]" limit="1"}}
        {{#foreach posts}}
                {{> content}}
            </article>
        {{/foreach}}
    {{/get}}
