Hello! I’m a newbie to ghost and not very advanced with coding either… That said, in the Liebling theme, I would like posts of a certain tag to NOT be displayed in the loop on the homepage, but just on the “tag page”. Is there a simple way to do this? Thank you!
Hi @jonahl,
welcome to ghost community
You can do that via the routes.yaml
in your Ghost Admin > Settings > Labs:
- Download your routes.yaml
- Add a filter under collections, like shown in the screenshot:
tag
= means you want to filter by tag
-yourcustomtag
= means, that posts withyourcustomtag
get excluded.
You can combine multiple tag filters, by adding a plus sign
Make sure to add the hyphen before your tag, otherwise your page will only show posts with that certain tag
More info in the ghost docs:
Let me know if you need help
Hey, @daniel1. Thank you so much, that works! I really appreciate it—I feel like a new world has been opened up…
Hi @daniel1 , I’ve done this. I want my blog frontpage to omit posts with the “wiki” tag, but my wiki page to include only posts with the “wiki” tag. So my solution is this:
However now I have everything on the blog page, and nothing on the Wiki page. Although I have several posts tagged as only wiki.
What am I doing wrong?
This is so cool. I added the
filter: tag:-mytag
And it worked in the home page.
However, navigating to that tag’s page, I click on a post with that tag and I get a 404. Any ideas here? @daniel1
Thanks for the help!
@pewu, the reason you get a 404 is that posts have to be in some collection in order to have a URL at all, because it’s the collection’s permalink
property that determines a post’s URL.
To fix it, you need to not just remove posts with your tag from the index collection, but also create a new collection that you put them in. That new collection can still have the same permalink
property as the index collection if you like, but its key in the collections
dictionary (which is the URL where you can view the collection) has to be different. If you don’t want a page where you can view the collection (because you want to use the tag page at /tag/mytag
instead), a hack that seems to work, at least for the current version of Ghost, is to just put some URL-illegal characters like ^
into the URL of the new collection. This, I think, will give you what you were looking for:
collections:
permalink: /{slug}/
template: index
filter: tag:-mytag
permalink: /{slug}/
template: index
filter: tag:mytag
