I want to insert post into ghost db using sql. If i’m using random number as post id it fails to display it then.
So: What’s the algorithm to generate post id?
Is there a reason you’re not using the Admin API for this? One of the main reasons for it existing is to make it easier for you do stuff like this - as long as you provide the minimum required data, Ghost will insert the post and return the details.
