Have a blog post and instead of the images being under each other I would like an easy way to place them side by side is there anyway to do this?
Can you use a gallery card? With two images in the gallery card they will be shown side by side.
hey thank you so much for the response, im using the casper theme how exactly do I use a gallery card
@Clow_Reed This webpage will show you how to insert a gallery card using the dynamic menu.
