How to replace the Article schema with NewsArticle in {{ghost_head}} (using PikaPods + Headline theme)?
Hi everyone,
I’m customizing the Headline theme and I want to replace the default JSON-LD schema @type: "Article" injected via {{ghost_head}} with @type: "NewsArticle".
I’ve already created a newsarticleschema.hbs file with the correct NewsArticle markup, and it works when inserted manually. However, when I include {{ghost_head}} in the <head>, it automatically adds the default Article schema, resulting in two conflicting schemas (Article and NewsArticle) on each post.
If I remove {{ghost_head}}, I lose important functionality such as:
  • Google AdSense
  • Social share buttons with embedded CSS
  • Code injection set in the Admin panel (header section)
Environment:
  • Ghost version: latest
  • Hosting: PikaPods
  • Theme: Headline
Question:
Is there a native or recommended way to override or replace the Article schema with NewsArticle in Ghost without removing {{ghost_head}}?
If not, is there any flag, helper, or clean workaround to handle this properly at the theme level?
Thanks in advance.
Yes! I did something about this last year:
You will need to edit the theme. So what you’re going to do is find where default.hbs currently calls {{ghost_head}}. Wrap that in some logic.
So perhaps, if you want to write custom schema only for posts or pages that have the tag #use-alt-schema:
(caution, made up on the spot, could have an error)
{{#is "post, page"}}
{{#post}}
  {{#has tag="#use-alt-schema"}}
      {{> newsarticleschema }}  {{!-- assumes this file is in partials --}}
      {{ghost_head exclude="schema"}}
  {{else}}
      {{ghost_head}}
  {{/has}}
{{/post}}
{{else}}
   {{ghost_head}}
{{/is}}
You’ll need to make sure you’re writing out a full set of schema for the pages that you’re excluding it from ghost_head. Be sure to include author, organization, etc.
