Hello,
I’ve migrated my website from WordPress to Ghost and loved it :) Some of my posts don’t have a tag, but I can’t see them in the admin page… Is there a way to discover them or should I have to go in SQL ?
Post tags can be found by viewing a post in Ghost admin and clicking the cog icon in the top right. You’ll then see a field to add tags on the right hand side:
Ok for that
But I have some posts which were imported without tags - is there a way to find them please ?
Since this is a one-off thing, you could use the Ghost API to fetch posts with tags and filter the posts based on ones without tags
Hello :) Thanks to fueko, here the solution :
Post without tag and with tag:
“in 2.1.0” this is tag so the first post has no tag.
Easy !! :)
