Hi, I want to take the first post from the posts list to make it a different style. I used this code but it doesn’t work.
Can you take a look on it?
{{#foreach posts}}
{{#has number="nth:1"}}
<h4><a href="{{url}}" class="card-title">Long posts</a></h4>
{{/has}}
<h4><a href="{{url}}" class="card-title">Short post</a></h4>
{{/foreach}}
Please let me know
Kevin
2
@ENAMUL_HAQUE I think you want {{#has number="1"}} because you only want the single first post.
The nth:x syntax is saying “every x posts”, in your case because you’ve set it to "1" you’re effectively saying “every other post”.
Thank you for your reply.
I want my first post should come from different post card.
Like this:
{{#foreach posts}}
{{> "post-card-full"}}
{{/has}}
{{> "post-card"}}
{{/foreach}}
But it is not working. All odd number posts are coming from this {{> "post-card-full"}} card.
How can I show only the first post?
Thanks
Kevin
4
I explained above
You need number="1" not number="nth:1"
Thanks a lot. The problem is solved
