Is #foreach
required when using #get
or can you use #post
? I looked through documentation and it wasn’t clear. Sorry for such a short post.
Yes, when you are working with a list of posts the {{#foreach}}
is needed to give you the post context.
The {{#post}}
is available in the post layout for a single post.
Thanks. I was wondering why I couldn’t get it working without the foreach. When I get some more time I might dig into why the homepage has an array while the post layout i’m guessing is not.
