Running Ghost Pro with the latest version.
I used an HTML card to place an image to the side with text wrapping around it, and it completely changed the body text font for the whole post.
Link with the problem:
This book, and this trilogy, is the best thing to come out of Star Wars in some time. You should read it. It's well worth your time, even if you aren't much of a Star Wars fan.
Link to a post without the problem:
The HTML Card I’m using
Sorry, it rendered the HTML. The card text is this:
It seems your <div class="container"> does not have a closing </div> tag. And that is causing the issue you are experiencing.
Kevin
April 10, 2021, 3:50pm
4
You’re missing a </div> at the end of your html. Without it all of the following content will be put into the .container div and inherit the styles for that class
