I’m encountering an issue with HTML formatting when using Ghost with Make.com. When I use the /html option in the Ghost editor and paste my custom HTML, everything works perfectly. However, when I try to publish posts using the Ghost module from Make.com, the HTML code gets formatted as plain text instead of being rendered correctly.
I’ve made sure to set the “Type of Content” parameter to HTML in the Make.com module, but it still doesn’t display properly. I haven’t tried it with Zapier yet, but I imagine the issue would be the same.
Has anyone else experienced this issue or found a solution?
Thanks for your help!
