Blog URL:https://recaptime.glitch.me/ Ghost Version 2.21.0 Configuration/Environment: I’m in the development environment Browser/Device: Chrome 76 Official Built 64-bit on Windows 8 64-bit Screenshot:
Hi. I was stressed out looking where is the directory the Ghost is installed. Actually, I’m also finding it to do the 2.30.1 update. Where is that directory (and how to do the update on Glitch)?
Hi there. I just tried using the same setup on Glitch. Are you able to access the database? There might be an entry called migrations_lock which stops migrations from happening when Ghost is updated, if you can delete that then the migrations should happen and the update should work again.
