I’m trying to import from an old ghost installation and I get the message:
Import failed
Value in [settings.type] cannot be blank.
{"key":"routes_hash","value":null,"created_at":"2020-09-08T20:24:19.000Z","created_by":"1","updated_at":"2020-09-08T20:24:19.000Z","updated_by":"1"}
I’m not sure about the error, but I wonder if you can do more incremental upgrade? maybe try jumping to ghost 3.0 first? If you use docker to setup a test environment at least would be pretty trivial to do so.
I tried going to ghost 3 before but I received the exact same error message.
This install uses mariadb and the images are stored on a minio server, but I don’t think this should be the reason for the non-import issue.
When you say you’re importing, are you doing a JSON import aka. export all posts and importing via labs?
The reason i’m asking is because I don’t see anything resembling settings.type in my export.
I haven’t used minio though I have some experience with kubernetes. I don’t think that should cause an issue. The only reason i was mentioning docker is the ease of use when changing versions.
Side note, I export content from 2.38 and imported into 4.0.1 and didn’t see any problems. So at least the bump is possible to go from 2.x to 4.x
