I found instructions for Dawn to add an alternate image for dark mode (so you’d have a white logo):
White Logo
When it’s in dark mode, a white version of the logo will be needed unless you’re using a text logo. In this case, you can enter the logo URL in
partials/customize/config.hbsfile.white_logo: 'yourblog.com/content/images/IMAGE_URL.jpg',Note: Remember to restart your Ghost when you made a change in hbs file.
These instructions don’t work since there is no partials/customize folder. So how do I do this with the current version of this theme?
Also, changes to the CSS don’t seem to push or update on Ghost, but I guess I can use code injection instead, unless someone has some idea.
