Hello everyone,
I need some help with Dawn theme customization. Honestly, I need minor changes, and if you can, help would be awesome. I’m not a developer at all, and it’s quite difficult to do it by myself. If you can recommend someone, that will be great. Thank you. ![]()
For a better understanding.
I need to place a bigger image in the center and add a headline and normal text. Also, move the top menu to the center. Remove subscribe button from the top and the button and keep only one on the main page. If I can set a smaller height and weight for the logo would be great as well. And if I can create a separate page for Archive just with a topics list, as on the main page, that would be awesome. Actually, that’s it. ![]()
