As far as I can tell, tiers always display in ascending order of price. Is there a way to reverse that? Or use a custom order (similar to the header image that Ghost itself used to announce improvements to the feature)?
Any formatting options available? Even simple ones like bold, italics or different bullet icons in the list of benefits per tier?
Currently, Ghost sorts tiers by price only. Custom order isn’t supported yet, but you can style or reorder them manually with code tweaks in your theme.
Yeah, but only on a custom page, I think? The Portal pop ups seem self-contained and inaccessible, even with Javascript.
For some reason, my tiers aren’t displaying correctly. My lowest tier is listed last, and I can’t figure out why. My pricing is set up in tiers of 5, 10, 20, etc., and the same goes for the yearly pricing, but the actual visual alignment isn’t matching up. Any idea?
Is this in the popover portal, or in your theme itself?
