Is it possible to have an SVG logo?
I tried to upload an SVG version of a logo and, though it is recognised and accepted in the settings, the front end appears to ignore it. I have tried with other SVGs and the same result occurs.
Is this an error with my installation or is this not currently supported. If it isn’t supported, is there a work-around?
Thank you in advance :).
Hey @unfurbled, can you please tell which part of front end is ignoring it? Uploading SVG version of logo in Settings -> General -> Publication logo is supported.
Hello @rishabhgarg. Thank you for your response.
“Settings -> General -> Publication logo”
Yes, this is how it was uploaded and I can see it displayed.
Though, it is not appearing where it should on the website – if I use a png everything works.
Website: outlearn
I appreciate your assistance.
Hi again @rishabhgarg
I have solved the issue. It appears that, for Ghost to render the logo, the height and width attributes are needed to be included in the SVG code (for example: viewBox=“0 0 600 72” height=“72” width=“600”).
As soon as I assigned these values the SVG displayed as it should.
I hope this helps someone else.
Thank you again for your time. :slight_smile:
