Hey everyone,
I’ve been working on a sample Dokploy template for the Dokploy/templates GitHub repo and wanted to check if this setup looks correct before I submit it.
It’s a Ghost blog deployment with MySQL, optional Tinybird analytics, and ActivityPub support.
Here’s the docker-compose.yml I wrote:
(full code block)
version: "3.8"
services:
ghost:
image: ghost:${GHOST_VERSION}
restart: always
env_file:
- .env
environment:
NODE_ENV: production
url: https://${DOMAIN}
# admin__url: https://${ADMIN_DOMAIN}
database__client: mysql
database__connection__user: ${DATABASE_USER}
database__connection__password: ${DATABASE_PASSWORD}
tinybird__tracker__endpoint: https://${DOMAIN}/.ghost/analytics/api/v1/page_hit
tinybird__adminToken: ${TINYBIRD_ADMIN_TOKEN}
tinybird__workspaceId: ${TINYBIRD_WORKSPACE_ID}
tinybird__tracker__datasource: analytics_events
tinybird__stats__endpoint: ${TINYBIRD_API_URL}
ACTIVITYPUB_TARGET: ${ACTIVITYPUB_TARGET:-http://activitypub:8080}
volumes:
- ${UPLOAD_LOCATION}:/var/lib/ghost/content
depends_on:
db:
condition: service_healthy
tinybird-sync:
condition: service_completed_successfully
required: false
tinybird-deploy:
required: false
activitypub:
condition: service_started
required: false
db:
image: mysql:8.0.42@sha256:4445b2668d41143cb50e471ee207f8822006249b6859b24f7e12479684def5d9
restart: always
environment:
MYSQL_ROOT_PASSWORD: ${DATABASE_ROOT_PASSWORD}
MYSQL_USER: ${DATABASE_USER}
MYSQL_PASSWORD: ${DATABASE_PASSWORD}
MYSQL_DATABASE: ghost
MYSQL_MULTIPLE_DATABASES: activitypub
volumes:
- ${MYSQL_DATA_LOCATION}:/var/lib/mysql
- ./mysql-init:/docker-entrypoint-initdb.d
healthcheck:
test: mysqladmin ping -p$$MYSQL_ROOT_PASSWORD -h 127.0.0.1
interval: 1s
start_period: 30s
start_interval: 10s
retries: 120
traffic-analytics:
image: ghost/traffic-analytics:1.0.9@sha256:693e752f420b8b1bfcf9867946a09966552a15d4797b86b90ecf3d1dd0e1067c
restart: always
volumes:
- traffic_analytics_data:/data
environment:
PROXY_TARGET: ${TINYBIRD_API_URL}/v0/events
SALT_STORE_TYPE: ${SALT_STORE_TYPE}
SALT_STORE_FILE_PATH: /data/salts.json
TINYBIRD_TRACKER_TOKEN: ${TINYBIRD_TRACKER_TOKEN}
LOG_LEVEL: debug
profiles: [analytics]
activitypub:
image: ghcr.io/tryghost/activitypub:1.1.0@sha256:39c212fe23603b182d68e67d555c6b9b04b1e57459dfc0bef26d6e4980eb04d1
restart: always
volumes:
- ${UPLOAD_LOCATION}:/opt/activitypub/content
environment:
PORT: 8080
MYSQL_HOST: db
MYSQL_DATABASE: activitypub
ALLOW_PRIVATE_ADDRESS: true
USE_MQ: false
LOCAL_STORAGE_PATH: /opt/activitypub/content/images/activitypub
LOCAL_STORAGE_HOSTING_URL: https://${DOMAIN}/content/images/activitypub
depends_on:
db:
activitypub-migrate:
profiles: [activitypub]
tinybird-login:
build:
context: ./tinybird
dockerfile: Dockerfile
working_dir: /home/tinybird
command: /usr/local/bin/tinybird-login
volumes:
- tinybird_home:/home/tinybird
- tinybird_files:/data/tinybird
tty: false
restart: no
tinybird-sync:
command: >
sh -c "
if [ -d /var/lib/ghost/current/core/server/data/tinybird ]; then
rm -rf /data/tinybird/*;
cp -rf /var/lib/ghost/current/core/server/data/tinybird/* /data/tinybird/;
echo 'Tinybird files synced into shared volume.';
else
echo 'Tinybird source directory not found.';
fi
volumes:
depends_on:
tinybird-login:
restart: no
tinybird-deploy:
build:
context: ./tinybird
working_dir: /data/tinybird
command: >
sh -c "tb-wrapper --cloud deploy"
volumes:
depends_on:
tinybird-sync:
tty: true
image: ghcr.io/tryghost/activitypub-migrations:1.1.0@sha256:b3ab20f55d66eb79090130ff91b57fe93f8a4254b446c2c7fa4507535f503662
environment:
MYSQL_DB: mysql://${DATABASE_USER}:${DATABASE_PASSWORD}@tcp(db:3306)/activitypub
depends_on:
db:
restart: no
volumes:
tinybird_files:
tinybird_home:
And here’s the .toml file for the template variables/config:
[variables]
main_domain = "${domain}"
admin_domain = "${domain}"
upload_location = "./data/ghost"
mysql_data_location = "./data/mysql"
ghost_version = "6-alpine"
database_password = "${password:32}"
database_root_password = "${password:32}"
tinybird_admin_token = "${password:32}"
tinybird_workspace_id = "${uuid}"
tinybird_tracker_token = "${password:32}"
tinybird_api_url = "https://api.tinybird.co"
[config]
[[config.domains]]
serviceName = "ghost"
port = 2368
host = "${main_domain}"
[config.env]
DOMAIN = "${main_domain}"
# ADMIN_DOMAIN = "${admin_domain}"
UPLOAD_LOCATION = "${upload_location}"
MYSQL_DATA_LOCATION = "${mysql_data_location}"
GHOST_VERSION = "${ghost_version}"
DATABASE_USER = "ghost"
DATABASE_PASSWORD = "${database_password}"
DATABASE_ROOT_PASSWORD = "${database_root_password}"
TINYBIRD_ADMIN_TOKEN = "${tinybird_admin_token}"
TINYBIRD_WORKSPACE_ID = "${tinybird_workspace_id}"
TINYBIRD_TRACKER_TOKEN = "${tinybird_tracker_token}"
TINYBIRD_API_URL = "${tinybird_api_url}"
ACTIVITYPUB_TARGET = "http://activitypub:8080"
Notes:
The Tinybird analytics service is throwing errors right now, but that’s because I haven’t given it correct API values yet so I’m not too worried about that.
I do need help getting the ActivityPub part working correctly with Ghost.
My questions:
Is there anything in my Docker Compose file that might cause issues when running in Dokploy?
Are the
depends_onconditions and profiles correctly set up for optional services like analytics and ActivityPub? -
For ActivityPub, am I setting the MySQL and storage paths right? Any extra env vars I should be aware of?
Do the
.tomlvariables match best practices for Dokploy templates?
Any feedback from those familiar with Dokploy, Ghost in Docker, or ActivityPub setup would be awesome ![]()
