Cool. I run mine on the $6 version (new intel). Works like butter in the sun.
I just saw you already dismissed this option because they donāt have the particular theme you want for free.
But for completeness of the thread for others who look here, I wanted to include this option.
Did you try new AMD?
I highly recommend Qovery. Itās a new service and it allows you to set up your whole Ghost blog from a template, so you donāt have to install it.
There are a few downsides:
- No(t yet) access to SSH or sth like Ghost CLI
- No direct access to your image files via your filesystem( ā I found a workaround for that)
- Setting up a custom domain does requires a little bit of work, but isnāt very complicated
But all in all I think itās a great way to host Ghost for free without installing it.
As a noob, I do not know what Docker or CI/CD or DevOps or even WWW meanā¦but I know a shiny new tool when I see itā¦this Qovery thing seems promisingā¦I was once able to install a Ghost instance on Heroku using a starter, it was simple ā¦and Qovery claims itās a Heroku killer:
Thanks for sharing @ralphjsmit and please tell us more if you canā¦would love to read a guide on your blog about how this works
Hey Joseph, installing Ghost on Qovery is very simple (step 1 - 5). Configuring though is a little bit more work and involves some basic use of Git and the command line.
- Login to Qovery with your GitHub account
- Create a new Project
- Create a new Application > From a template > Ghost
- Follow the installation steps. Qovery will create a GitHub repo in your account.
- You now have your own Ghost installation on a domain like ghost-router-XXXXXXXXX.qovery.io.
Custom domain
6. Add a custom domain like this: Custom domain | Qovery
7. Change your .env
file to this:
url=$QOVERY_ROUTER_GHOST_ROUTER_CUSTOM_DOMAIN_URL
How to āownā your content
Your content exists of two things:
- Uploaded images (+ themes)
- Members, posts, etc.
- You donāt have access to the
/content/
folder if you want to host for free. - I found a workaround for this involving Netlify. It is a bit to complicated to explain here.
- All members, posts, etc can simple be exported from inside Ghost and imported in a new (fresh) installation at will.
How to update
Add a new commit in GitHub
Blog post
I totally agree that this can seem very daunting as a beginner. One year ago Iād have found this also daunting
I absolutely plan to write a blog post about the whole process in June, Iāll keep you updated and post it here when itās ready.
Thanks, looks promising, I was able to get to deploying stage in under 2 minutes
Can confirm Qovery works easy-peasyā¦magicalā¦it does use SQLite3 as the database (which is not recommended, as it creates issues when membership hits 100s)ā¦however, my understanding is that Qovery is especially strong with running databases for appsā¦I just have to figure how to run it
