- What’s your URL? http://18.217.96.243:2369/ghost
- What version of Ghost are you using? Latest version
- What configuration? Ubuntu 16 on AWS with Nginx
- What browser? Chrome
- What errors or information do you see in the console? Nothing
- What steps could someone else take to reproduce the issue you’re having? Setuo ghost on Ubuntu 16 on AWS with Nginx
Could you provide more information @sophiaturka? “Latest version” isn’t helpful, what’s the version number? Could you share the steps you went through to install Ghost?
Hello David,
I’m installing Ghost v3.11.0 and I am following these steps to install Ghost on Ubuntu: How to install & setup Ghost on Ubuntu 16.04, 18.04, 20.04 or 22.04
Thank You
Great, thanks. Are you able to run ghost doctor? It should give a log of what is working and not working
You should be accessing your site with the blog URL (without port number) you’ve entered while you were installing Ghost through Ghost CLI. When you install Ghost, it configures Nginx reverse proxy to allow connections from outside (port 80, 443) to your Ghost instance (port 2368). If you still cannot access your site even without port number, make sure you’ve opened ports 80 and 443 on your EC2 instance. Connect to an Amazon EC2 instance on HTTP or HTTPS ports
Hey @minimaluminium
Thanks for your comment.
Yes, I checked in AWS inbound settings and 80, 443 & 2368 are already enabled but still throwing error when try to open http://blog_url:2368 “Site can’t be reached”.
But when I open http://blog_url it shows NGINX page displaying " Welcome to nginx!".
Can you check if your.domain.conf exists in YOUR_BLOG/system/files? Also have you reloaded Nginx?
Ok, I have created new instance on AWS and trying on it. Will get back to you after checking the same within few minutes.
@minimaluminium
I got the same issue with new instance.
No I haven’t reloaded NGINX.
please let me know how to check .domain.conf file?
I am having the same issue. My .conf file exists in blog_dir/system/files and everything looks correct.
