Upgrade ghost 5.71.0 with node 18, encountered error
Upgrading Ghost to v5.71.0 with Node.js v18.18.2, I encountered database errors when start ghost.
Ghost version 5.70.2 is running smoothly with Node.js 16.20.
+ sudo systemctl is-active ghost_mydomain-com
✔ Checking system Node.js version - found v18.18.2
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking systemd unit file
✔ Checking systemd node version - found v18.18.2
+ sudo systemctl start ghost_mydomain-com
+ sudo systemctl stop ghost_mydomain-com
✖ Starting Ghost: mydomain-com
A GhostError occurred.
Message: Ghost was able to start, but errored during boot with: connect ECONNREFUSED ::1:3306
Help: Unknown database error
Suggestion: journalctl -u ghost_mydomain-com -n 50
    OS: Ubuntu, v22.04.3 LTS
    Node Version: v18.18.2
    Ghost Version: 5.71.0
    Ghost-CLI Version: 1.25.3
    Environment: production
    Command: 'ghost start'
Additional log info available in: /home/user/.ghost/logs/ghost-cli-debug-2023-10-27T19_15_29_412Z.log
The error logs:
[2023-10-27 19:22:46] ERROR connect ECONNREFUSED ::1:3306
"Unknown database error"
Error ID:
    500
Error Code:
    ECONNREFUSED
Error: connect ECONNREFUSED ::1:3306
    at /dir/versions/5.71.0/node_modules/knex-migrator/lib/database.js:57:19
    at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1555:16)
Has anyone else encountered a similar situation?
Looks like your database isn’t running, or isn’t accepting connections. Can you connect to it on the command line (which would confirm that it’s up)?
Yes, I have the same issue.
Still can’t fix it.
Mysql is running,
nodejs is already the newest version (18.18.2-1nodesource1).
Tried ghost setup, still no success
Node 18 prefers ipv6 resolution over ipv4 - you can see this in the error message with the MySQL connection ::1:3306. If your MySQL server isn’t listening on the ipv6 interface then node won’t be able to connect to it.
Quickest fix is probably explicitly specifying 127.0.0.1 for your database host in place of localhost in your Ghost config.
Amazing @Kevin
Thanks a lot! Worked for me.
