hi i was to install ghost but this error came
https://careers.ghost.org
✔ Checking system Node.js version - found v18.14.2
✔ Checking free space
✔ Setting up install directory
✖ Downloading and installing Ghost v5.37.0
A ProcessError occurred.
warning ghost@5.37.0: The engine "cli" appears to be invalid.
warning Resolution field "@elastic/elasticsearch@8.5.0" is incompatible with requested version "@elastic/elasticsearch@8.6.0"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@^2.29.1"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.29.1"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@^2.27.0"
warning Resolution field "moment-timezone@0.5.23" is incompatible with requested version "moment-timezone@^0.5.31"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.29.4"
warning Resolution field "moment-timezone@0.5.23" is incompatible with requested version "moment-timezone@0.5.34"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.29.3"
warning Resolution field "moment-timezone@0.5.23" is incompatible with requested version "moment-timezone@^0.5.33"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.27.0"
warning Resolution field "@tryghost/logging@2.4.1" is incompatible with requested version "@tryghost/logging@2.4.0"
error An unexpected error occurred: "https://registry.yarnpkg.com/@stdlib/blas/-/blas-0.0.12.tgz: ESOCKETTIMEDOUT".
yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
info There appears to be trouble with your network connection. Retrying...
info If you think this is a bug, please open a bug report with the information provided in "/var/www/mawtechblog/versions/5.37.0/yarn-error.log".
info Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command.
Exit code: 1
OS: Ubuntu, v22.04.2 LTS
Node Version: v18.14.2
Ghost-CLI Version: 1.24.0
Environment: production
Command: 'ghost install'
Additional log info available in: /home/ghostblog/.ghost/logs/ghost-cli-debug-2023-03-06T11_29_36_120Z.log
