Problems installing Ghost on Ubuntu
Can someone help with this? I’m trying to install Ghost on my Ubuntu, but got this
A ProcessError occurred.
warning ghost@3.32.1: The engine “cli” appears to be invalid.
warning Resolution field “moment@2.24.0” is incompatible with requested version “moment@2.27.0”
warning Resolution field “moment-timezone@0.5.23” is incompatible with requested version “moment-timezone@0.5.28”
warning Resolution field “moment-timezone@0.5.23” is incompatible with requested version “moment-timezone@0.5.31”
error An unexpected error occurred: “https://registry.yarnpkg.com/moment/-/moment-2.24.0.tgz: unable to get local issuer certificate”.
yarn install v1.22.4
[1/5] Validating package.json…
[2/5] Resolving packages…
[3/5] Fetching packages…
info If you think this is a bug, please open a bug report with the information provided in “/var/www/ghost/versions/3.32.1/yarn-error.log”.
info Visit yarn install | Yarn for documentation about this command.
Exit code: 1
OS: Ubuntu, v18.04.5 LTS
Node Version: v12.18.3
Ghost-CLI Version: 1.14.1
Environment: production
Command: ‘ghost install’
Additional log info available in: /home/toporov/.ghost/logs/ghost-cli-debug-2020-09-09T10_51_02_526Z.log
Hi Alex,
is your machine running behind a webproxy?
I just had the same error on many attempts to install Ghost 4.3.2 on my DO Ubuntu 20.04 instance. In the end, I found Github poster just commented that this would fix the issue:
$ yarn cache clean
It worked.
