preinstall question, for install digitalocean to other server? i use cpanel example
ghost.droplet.com to blog.domain.com with cname
it’s possible?
regards
it’s possible?
regards
yes… Its possible.
have tutorial? or cost for implement bro
regards
I can make u a tutorial at no cost bud!..
I need more details on your current server status…
To understand the scenario the flow is:
Something like Server A has ghost installed with a domain pointed ghost.droplet.com & You want to make that instance (ghost.droplet.com) accessible from another domain (blog.domain.com) right?
Great!
yes exactly, for navigate from blog.domain.com
or if is possible install ghost in hosting with cpanel, i think frpm shell? for direct in blog.domain.com
regards
Check out on your cpanels Softaculous Apps installer… if you find the Ghost Under Blog Category then you can install… Otherwise you have to install Ghost on cpanel Manually… Which i never tried
But you want to use cname Redirection The go to DNS Editor for the domain you want to redirected to & Add the following records
Record Type cname
DATA: ghost.droplet.com
& then Change the URL on your ghost config.production.json to blog.domain.com
Above will solve your problem…
Let me know if you have any Q.
Thanks
