JSON Export using ghost CLI
It seems my Ghost installation is hacked as there are multiple .php files and website is getting 503 error. I am able to download content folder using FTP with Cyberduck but am unable to access the Labs JSON export webpage. Is it possible for me to use ghost CLI for export? I apologize if this has been shared before, but I could not find it anywhere.
To avoid further damage, my plan is to restart the droplet on the digitalocean and reinstall ghost. I can access the database from serverpilot.io if that helps.
  • What’s your URL? https://ieos.org
  • What version of Ghost are you using? v2.31.1
  • What configuration?
  • What browser? Chrome
The malware besides creating PHP scripts slowing the PHP also deleted the configuration file. By recreating the configuration file, I was able to restore the connection with the database. Backed up JSON, content and recreating DigitalOcean droplet. :cold_sweat:
Well done for getting a backup. Are you starting over with a fresh install?
Yes, deleted the droplet even, reinstalled centOS, serverpilot and fresh ghost install 3.0 with import.
