- What’s your URL? This is the easiest way for others to debug your issue
https://edgeform.host - What version of Ghost are you using?
Ghost 3.13.4, CLI 1.13.1 - What configuration?
Default - What browser?
N/A - What errors or information do you see in the console?
When I initially log into the Ghost Droplet, here is the output: https://pastebin.com/eYuWDm3x
Here is the log file created by the installer: https://pastebin.com/vFjw1uQ5
Here is the output ofacme.shfrom the install script with--debug 2added, error is line 328: https://pastebin.com/HktYcHTN - What steps could someone else take to reproduce the issue you’re having?
Spin up a new Ghost Droplet with a Cloudflare-protected domain.
Scratching my head on this one folks. I’m not sure why the acme challenge isn’t showing up correctly. Perhaps it’s a Cloudflare issue from some of the output I’m seeing in the --debug 2 log. Any help or guidance is appreciated!
EDIT: I should note that I did enable development mode on the domain prior to doing all of this to try and keep Cloudflare’s involvement to a minimum for setup.
