Links not displaying correctly in callout box
  • I regularly use a callout box in our accent colour (red), in which both text and links would previously appear in white
  • Links elsewhere on our site would usually appear in our accent colour
  • At some point since March 19, links within a callout box have also started showing in our accent colour … which renders them completely invisible
Setup information
Ghost Version
6.25.0-rc.0+937288a
We do not self-host (as far as I’m aware). This error is appearing on Windows but replicated on Android, at the least.
Browser & OS version
Chrome Version 146.0.7680.165
this is probably a conflict between card styles and theme styles or code injection. You can likely fix it with a little code injection (or by removing some code injection causing the problem). Link a page (draft preview is fine) with the problem if you want help with it.
