Hey everyone,
i am using the free theme “alto” and i had the same problem with the default theme “casper”:
When i link a url to a text then i can not see the text when publishing. It is invisible.
When i look at the preview then it looks like this
I appreciate any help
Laurin
Have you adjusted your theme files at all?
Or maybe check your design settings in Ghost Admin. Maybe your accent color is set to be white?
Yes figured it out. Did not know that the accent colors are linked to the url and did also not know that the #ffffff stand for white.
Found this information about all css colors
https://www.w3.org/wiki/CSS/Properties/color/keywords
