Local Portal.js error
Ghost-CLI version: 1.21.0
Ghost version: 5.3.1
I have downloaded minified portal.min.js file and added to the local path, unminified, edited Ghost config file by adding this:
"portal": {
    "url": "/assets/built/portal.js",
    "version": "2.3"
Unfortunatelly portal functionality doesn’t work. I get this error:
Uncaught ReferenceError: fl is not defined
I think changing minified file into unminified might broke the code. Perhaps someone know the solution?
I wanted to have local portal.js for translation purposes.
I don’t think there’s enough information to understand what’s going on here.
Does your error show where it’s originating from? Did you try to re-add the portal code?
