I’m having a problem starting Ghost on my Raspberry Pi. It’s always worked until recently when I’ve started getting an error with MariaDB.
Ghost-CLI version: 1.15.3
URL: Corballis.co.uk [not that you can get there due to the error described below]
Ghost version: 3.0
Configuration:
OS: Raspbian GNU/Linux, v9
Node Version: v10.16.0
Ghost-CLI Version: 1.15.3
Environment: production
Command: ‘ghost update’
mysql Ver 15.1 Distrib 10.1.23-MariaDB, for debian-linux-gnueabihf (armv7l) using readline 5.2
Note, Ghost Update fails with:
An error occurred.
Message: ‘Invalid Version: null’
- How was Ghost installed and configured? Via npm.
- No browser - running headless, I log in via ssh
- What errors or information do you see in the console? See below
- What steps could someone else take to reproduce the issue you’re having? Not sure
Error message
MariaDB connect ECONNREFUSED 127.0.0.1:3306 Error ID: 500 Error Code: ECONNREFUSED
and, also:
ERROR 2002 (HY000): Can’t connect to local MySQL server through socket ‘/var/run/mysqld/mysqld.sock’ (2 “No such file or directory”)
Here’s the output from Ghost Doctor:
tc@my-pi:/var/www/xxxxx.com $ ghost doctor
Checking system Node.js version
Checking logged in user
Ensuring user is not logged in as ghost user
Checking if logged in user is directory owner
System checks failed with message: ‘Linux version is not Ubuntu 16, 18, or 20’
For local installs we recommend using ghost install local instead.
? Continue anyway? Yes
System stack check skipped
Checking system compatibility [skipped]
Checking for a MySQL installation
- sudo systemctl is-active ghost_undefined
- sudo systemctl reset-failed ghost_undefined
Validating config
Checking folder permissions
Checking file permissions
Checking memory availability
Checking binary dependencies
Checking free space
This is from my database log:
Dec 24 12:44:10 my-pi node[7182]: [2020-12-24 11:44:10] WARN Retrying…
Dec 24 12:44:10 my-pi node[7182]: [2020-12-24 11:44:10] WARN Can’t connect to the bootstrap socket (localhost 8000) ECONNREFUSED.
Dec 24 12:44:10 my-pi node[7182]: [2020-12-24 11:44:10] WARN Tries: 2
Dec 24 12:44:10 my-pi node[7182]: [2020-12-24 11:44:10] ERROR connect ECONNREFUSED 127.0.0.1:3306
Dec 24 12:44:10 my-pi node[7182]: connect ECONNREFUSED 127.0.0.1:3306
Dec 24 12:44:10 my-pi node[7182]: “Unknown database error”
Dec 24 12:44:10 my-pi node[7182]: Error ID:
Dec 24 12:44:10 my-pi node[7182]: 500
Dec 24 12:44:10 my-pi node[7182]: Error Code:
Dec 24 12:44:10 my-pi node[7182]: ECONNREFUSED
Dec 24 12:44:10 my-pi node[7182]: ----------------------------------------
Dec 24 12:44:10 my-pi node[7182]: DatabaseError: connect ECONNREFUSED 127.0.0.1:3306
Dec 24 12:44:10 my-pi node[7182]: at DatabaseError.KnexMigrateError (/var/www/xxxxxx.com/versions/3.34.0/node_modules/knex-migrator/lib/errors.js:7:26)
Dec 24 12:44:10 my-pi node[7182]: at new DatabaseError (/var/www/xxxxxx.com/versions/3.34.0/node_modules/knex-migrator/lib/errors.js:55:26)
Dec 24 12:44:10 my-pi node[7182]: at connection.raw.catch (/var/www/xxxxxx.com/versions/3.34.0/node_modules/knex-migrator/lib/database.js:47:19)
Dec 24 12:44:10 my-pi node[7182]: Error: connect ECONNREFUSED 127.0.0.1:3306
Dec 24 12:44:10 my-pi node[7182]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
Dec 24 12:44:10 my-pi node[7182]: at Protocol._enqueue (/var/www/xxxxxx.com/versions/3.34.0/node_modules/mysql/lib/protocol/Protocol.js:144:48)
Dec 24 12:44:10 my-pi node[7182]: at Protocol.handshake (/var/www/xxxxxx.com/versions/3.34.0/node_modules/mysql/lib/protocol/Protocol.js:51:23)
Dec 24 12:44:10 my-pi node[7182]: at Connection.connect (/var/www/xxxxxx.com/versions/3.34.0/node_modules/mysql/lib/Connection.js:116:18)
Dec 24 12:44:10 my-pi node[7182]: at Promise (/var/www/xxxxxx.com/versions/3.34.0/node_modules/knex-migrator/node_modules/knex/lib/dialects/mysql/index.js:69:18)
Dec 24 12:44:10 my-pi node[7182]: at Promise._execute (/var/www/xxxxxx.com/versions/3.34.0/node_modules/bluebird/js/release/debuggability.js:384:9)
Dec 24 12:44:10 my-pi node[7182]: at Promise._resolveFromExecutor (/var/www/xxxxxx.com/versions/3.34.0/node_modules/bluebird/js/release/promise.js:518:18)
Dec 24 12:44:10 my-pi node[7182]: at new Promise (/var/www/xxxxxx.com/versions/3.34.0/node_modules/bluebird/js/release/promise.js:103:10)
Dec 24 12:44:10 my-pi node[7182]: at Client_MySQL.acquireRawConnection (/var/www/xxxxxx.com/versions/3.34.0/node_modules/knex-migrator/node_modules/knex/lib/dialects/mysql/index.js:64:12)
Dec 24 12:44:10 my-pi node[7182]: at create (/var/www/xxxxxx.com/versions/3.34.0/node_modules/knex-migrator/node_modules/knex/lib/client.js:291:39)
Dec 24 12:44:10 my-pi node[7182]: at process._tickCallback (internal/process/next_tick.js:68:7)
Dec 24 12:44:10 my-pi node[7182]: at Function.Module.runMain (internal/modules/cjs/loader.js:832:11)
Dec 24 12:44:10 my-pi node[7182]: at startup (internal/bootstrap/node.js:283:19)
Dec 24 12:44:10 my-pi node[7182]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
Dec 24 12:44:11 my-pi node[7182]: /usr/lib/node_modules/ghost-cli/lib/process-manager.js:52
Dec 24 12:44:11 my-pi node[7182]: throw error;
Dec 24 12:44:11 my-pi node[7182]: ^
Dec 24 12:44:11 my-pi node[7182]: [object Object]
Dec 24 12:44:11 my-pi systemd[1]: ghost_corballis-co-uk.service: Main process exited, code=exited, status=1/FAILURE
Dec 24 12:44:11 my-pi systemd[1]: ghost_corballis-co-uk.service: Unit entered failed state.
Dec 24 12:44:11 my-pi systemd[1]: ghost_corballis-co-uk.service: Failed with result ‘exit-code’.
Dec 24 12:44:11 my-pi systemd[1]: ghost_corballis-co-uk.service: Service hold-off time over, scheduling restart.
Dec 24 12:44:11 my-pi systemd[1]: Stopped Ghost systemd service for blog: corballis-co-uk.
– Subject: Unit ghost_corballis-co-uk.service has finished shutting down
– Defined-By: systemd
– Support: Debian -- User Support
